Help! Dropped a bolt down my preheater
Old 07-23-2016 | 04:59 PM
barngal6's Avatar
Have my air horn off and dropped a nut into the opening below.
It rolled a ways down, I can't see it. Haven't been able to retrieve with a magnet. What's the best way to get at it. It's a #10 nut, this is my intake so I assume I can't leave it, or I would.
Any suggestions I appreciate it, I'm stuck
Old 07-23-2016 | 06:19 PM
Magnet on a piece of fishing line would be my first choice.
If you can't get it, taking the intake plate off would work is a 2nd best plan.
Leaving it would be a distant 3rd choice.
Old 07-23-2016 | 07:32 PM
barngal6's Avatar
Took off the plenum, retrieved the nut. But the plenum gasket tore. Can I put it back together and patch some gasket maker or do I have to wait for a new gasket which won't come till Wednesday ?
Thanks
Old 07-24-2016 | 12:40 PM
jtamulonis's Avatar
Thanks
Just clean the head and plenum with laquor thinner or acetone, put a THIN bead of ultra-black or "the right stuff" silicone on the head and bolt the plenum down. it WILL NOT leak and make a longer lasting seal than the gasket. Been doing this for 40 years and no problems as long as the gasket is NOT used to set clearance on some transmission bearings.
barngal6 (07-25-2016)
grim
07-25-2010 06:23 PM
91.5CTDBanks
01-13-2010 08:13 PM
bek
21
09-14-2005 05:59 PM
12vordie
06-25-2005 01:14 PM
rigsy
10-26-2002 04:17 AM
Quick Reply: Help! Dropped a bolt down my preheater
