Heater grid gasket
Old 12-13-2005 | 01:19 PM
tmacie's Avatar
Heater grid gasket
Hi all,
Where can I get the gasket that goes between the heater grid and charge piping manifold? I tore mine a bit (****!) when I took it apart to have more room to install the 100 plate. My local stores dont have a listing, but do have a listing for a intake manifold set. Its special order so id have to pay for it jsut to look in the set. Anyone have any ideas?
Thanks,
Travis
Old 12-13-2005 | 01:52 PM
infidel's Avatar
Just cut one out from bulk gasket material sold at any autoparts.
Old 12-13-2005 | 02:21 PM
tmacie's Avatar
Thats a good idea. I might cut myself with the razor!!!! Waaa.
Thanks,
Travis
Old 12-14-2005 | 04:48 PM
Rammin On's Avatar
Don't mess with cutting your own ... you may be prone to boost leaks .. CUmmins P/N 3969988 ... get two depending on what year truck you have and you can trash the grid heater ground strap. This is the new PN for the new gasket.
Old 12-14-2005 | 07:01 PM
infidel's Avatar
Huh?
I've been making my own gaskets for forty years without a problem. I'm sure many here would say the same thing.
Old 12-14-2005 | 09:33 PM
tmacie's Avatar
Yeah as long as it doesnt rip, I dont see why it would leak over any other gasket....And sadly I dont have a cummins dealer close, only dodge dealers and im not paying $50 for a $5 gasket.
Travis
Old 12-14-2005 | 11:10 PM
oestreich84's Avatar
If it is the same as my 24 valve I can send you one. I got mine from NAPA and didn't need it. Just let me know.
Old 12-14-2005 | 11:45 PM
halerazor's Avatar
hailey machine has them for $12 for an aluminum or steel one
Old 12-15-2005 | 08:34 AM
Rammin On's Avatar
Not that you can't make your own ..... I've found plenty of "ho made" intake gaskets that were the cause of boost leaks ..... I too have fabricated more gaskets than i care to think about .....
Old 12-15-2005 | 10:29 AM
tmacie's Avatar
Rammin On,
I'm curious, were the hommade gaskets you have seen ripped, or just inconsistant material thickness?
Travis
SpeedyWS6
15
02-02-2011 07:22 PM
Ramrod90
02-03-2009 07:39 AM
CTD_Neil
03-20-2007 11:49 PM
taildragger
12-04-2006 10:00 AM
CTD_Neil
12-23-2004 11:18 AM
Quick Reply: Heater grid gasket
