Head studs
most likely 12's the 14's reqiure the block to be drilled and tapped and the head reamed and are for all out competition. A set of 12mm studs a marine gasket and orings are probably all you would need even for twins/nos ect.
Regular studs can hold up to 80 psi, far as ive read.. At that boost level ur well over the 600 horse range..
bigger question, which are the ones taht you dont have to grind the valve covers with?
Rick
12valvetom
11-27-2009 11:37 PM
dieselboy59
01-30-2009 03:57 PM
smokewagon
08-08-2008 09:54 PM
MikeThomas
05-11-2008 11:39 AM
jmccart
21
05-14-2007 11:47 AM
