HE351VE install and controller thread for 12 valve Cummins
Old 12-24-2011 | 01:02 AM
tech-eh's Avatar
nice actuator but slowwwww 4 seconds full open and close and the gearing inside may be plastic that doesn't like heat
Old 12-24-2011 | 08:49 AM
cj360trider's Avatar
Any suggestions? Id like to go that route to simplify things
Old 12-24-2011 | 08:53 AM
9812vram's Avatar
Yes, it needs to be pretty quick. Here's a quick snippet on how the VNT operates (I know it's not the same turbo as yours, but all VNT's work the same): http://www.honeywell.com/sites/ts/tt...s_VNTworks.htm
If the throat is reduced at low engine speed and you nail it - the turbo is almost instantly flooded with exhaust gasses. If the Actuator doesn't react right away - like almost milliseconds - your turbo will over-speed and produce a tremendous amount of boost in a second. On the VNT Deere tractors, (not sure about the new Cummins) when you turn the key on, one of the engine checks it does is to cycle the VNT actuator. It cycles it all the way, pauses, then cycles it back. Each way takes less than a second to reach full travel - the whole cycle is less than two seconds. I believe the reaction speed needs to be pretty quick.
The VNT isn't a waste gate - it doesn't just control boost at high pressure, it regulates boost right from 0psi up to the top end.
According to that link, it is possible to use a mechanical actuator. I'd look into that if you want simple....
Old 12-24-2011 | 06:02 PM
ill have to eiether use 1 electronic actuator for the entire op or use a mechanical and electronic in conjunction. id love to stick to 1 actuator
Old 12-25-2011 | 10:02 PM
9812vram's Avatar
How come you need two?
Old 12-25-2011 | 10:43 PM
tech-eh's Avatar
each turbo operates interdependently in terms of boost and opening of the waste gate because there is a timing differential with them you want one to open just before the other one
Old 12-25-2011 | 11:08 PM
i will have to use 2 actuators if i cant find a single actuator to operate both vgt and exh brake functions
Old 01-17-2012 | 09:00 PM
Epiphany
HE351VE install and controller thread for 12 valve Cummins-turbo-actuator.jpg
here is my latest idea
using a small pneumatic cylinder a spring and a 2 way line solenoid my thought is to use boost pressure override spring tension...much like a wastegate actuator but use the same cylinder with vacuum to actuate the Exh Brake. shud be able to find this cylinder at work keep you posted!
Old 01-18-2012 | 10:22 AM
9812vram's Avatar
Simple. I like it. Looks like it could work too!
Old 01-18-2012 | 11:31 AM
Found a cylinder at work I can use! Will post part number and pics when I get home tonite. Its for 6v or 8v detroit.
Old 01-18-2012 | 08:32 PM
supplier for these parts so far as I know is MCI and Prevost
HE351VE install and controller thread for 12 valve Cummins-partnumbersticker.jpg
Old 01-20-2012 | 10:09 PM
going to start on a mounting plate for the cylinder 2mro. gonna try make a plate that will seal the coolant passages off so i can still run coolant thru it. will post pics as soon as i have them uploaded
Old 02-03-2012 | 10:41 PM
400Magnum's Avatar
Good Luck with this! I'm very interested in seeing how this turns out.
Old 02-04-2012 | 11:05 AM
400Magnum dont wait too long to kill that dowel pin!!! its bite takes a nice chunk out of the wallet!
Old 02-06-2012 | 07:39 AM
400Magnum's Avatar
Yeah, I know, it's on the list of things that will get fixed in the next few months when I upgrade the brakes, fix the steering pump, flush the heater core, etc...
Quick Reply: HE351VE install and controller thread for 12 valve Cummins
