grinding from somewhere in the front...
i was driving today (obviously), felt a snap/jerk kind of like i ran over something and it got caught...with grinding that sounded like it was coming from the drivers side front wheel. it definitely is in the drivetrain and it changed a little with speed and not RPMs. hitting bumps made it louder.
i did a search...could this be something to do with a snap ring in the transfer case? wheel bearings? it was very sudden, so it didnt seem like a wheel bearing thing to me.
any help would be great. i parked it at a friends house for now.
Sounds like a wheel hub to me.
Jack up the side thats bad and grab the wheel at 12 and 6 and see if it moves. If it does its a wheel hub.
When mine went out the wheel would move about 2" when I checked it.
and wheres the best place to get one?
i replaced 4-5 wheel hub bearing assemblies on my old 95 half ton, the first time took about 5 hours, i can now do it in about 30-45. i am unsure how different the 3/4 and 1ton 4 wheel drives are.
my old 95 4x4 the cost of them from the local auto parts warehouse was $160ish
my 03 2x4 3/4 ton cost from the dealer was $475ish
my biggest hint if i were telling someone how to do a 95 is nubolt the giant castle nut on the axle before you start jacking it up or anything.
thanks.
Expect to pay around $200-$300 at the auto stores.
Summit has them here.
http://store.summitracing.com/partde...5&autoview=sku
www.rockauto.com has timken ones for $135.00. You can also get another %5 off by typing turbodiesel in the coupon box.
They also have fast shipping.
I order 99% of my parts from there.
you need a 12 point socket set (metric) and a big socket with a good impact or a large breaker bar to get that big nut loose. I think it is like a 1 1/2 or 1 5/8 or so, someone correct me on that please, and a brass drift or something comperable to knock the studs out. Other than that I thought they were fairly easy to change. The problems sounded like a wheel bearing failure to me. Mine wandered and rattled and banged over bumps and squeeked. It didn't up and fail all of a sudden but that doesn't mean they wont. If that isn't the problem then I would check your control arms or your shocks. when those control arms get hammered up mine drives terrible and makes a bad racket. As far as the shocks, when the bushings go bad then they make a lot of noise but drive fine.
