Gray valve cover gaskets??
I think I can... I think...
I purchased new V/C gaskets a while back and just put them on today.
I did a search for torque specs and found a thread that says NOT to use the gray ones. Well that's the ones that I have and since I already had the valve covers back on the truck before I decided to search for torque specs I left them on.
What's the reason for not using the gray gaskets?
Also I read that over torqueing the bolts will cause the gaskets to leak as bad as not to being tight enough.
The V/C bolts have a sleeve that bottoms out at the head, would the torque specs be more concern for twisting off the bolt and not so much concern for the gasket?
Just wondering out loud now.
The shop I paid to do my valve adjustment and timing (disclaimer: this was a LONG time ago ), replaced my old ones with the grey ones. I never had a problem, until I had to clearance my valve covers for the new head studs, and I over tightened #1 and it tore the gasket. I probably had 30,000 miles on them. I say run them. Worst case scenario, NAPA sells the black ones individually.
MIke
MIke
IIRC, the torque is 18 ft/lbs.
I've noticed on my truck, that the grey gaskets are a single use gasket. Any time I've tried to reuse them, they leaked. They get hard where they touch the head, and don't seal properly.
The grey ones are marine grade, IIRC.
I've had grey on for 10,000k no problems. My mechanic says these are better than the blacks, and though he is not the final say on everything, he is right so much of the time I trust him. He only works on these things 50hrs. a week.
Use the grey ones! The problem when reusing them is they tend to expand some and are hard to get back on the valve cover. Just pop them in the frezer for an hour and presto, they are back to size and ready for reuse.
The grey gaskets are the better part, just a bit more picky to install after they have been used.
Don~
Don~
Originally Posted by Junk Yard Dog
I'm with Bill on this one, I've also seen that Cummins is only selling the gray silicone gaskets, and eliminating the black rubber ones.
Rick
Rick
The grey ones is all that Cummins has, even Napa's gaskets are made by Cummins and they are dark grey but same silicone gaskets too.
They work fine, as long as you're not like me where I'm always taking off my valve covers tweaking things, then they become a PITA to reuse, and I don't care for them.
DiPaco is the only company still making the old black rubber gaskets. I like the black ones, the way I see it neither one lasts me forever anyway, but the black ones hold their shape and are easier to reuse.
Grey from cummins here as well and mine had been on for a year and a half with no leaks, ijust replaced them when i replaced my head. There are O rings around the vc bolts as well and the bolts bottom out on a shoulder.
