GEN light on
Old 04-02-2011 | 07:48 PM
MEEHAN's Avatar
GEN light on
my gen light will come on after about 10 mins of driving, ive changed the alternator already and the everything works still including the tach and voltage gauge it reads right at 12 volts,down from the normal 14 it usually displayed. the batterys still have a full charge. what could be the issue?
Old 04-02-2011 | 09:23 PM
rebal's Avatar
check your grounds make sure there clean and tight .also check the crank sensor and wires ,itr could also be the PCM
Old 04-03-2011 | 03:46 PM
MEEHAN's Avatar
Where exactly is the PCM, and crank sensor?
Old 04-03-2011 | 05:31 PM
dstad's Avatar
Pcm is behind the turbo on the firewall, their is no crank sensor on 12v unless rebal is refering to the tach pickup. I had the charging circuit in the pcm on my dads 96 go out and had to get my alt converted to internal regulation. It now works flawlessly.
Old 04-03-2011 | 05:50 PM
MEEHAN's Avatar
Thanks that helps a lot
Old 04-04-2011 | 06:05 AM
blackimpala's Avatar
It does more
That unit above the dampener is more than a tach sensor it has input to the PCM for the automatic transmission Also lets the computer know that the engine is running for other systems. If you put alt regulator on I think you mean external regulator. There are step by step instructions in this forum and others.
Floyd
Old 04-04-2011 | 12:34 PM
Lil Dog's Avatar
The Crank sensor and related wiring is usually the culprit with these types of problems. Where the wires go across from the IP and head then turn down behind the fan, they can become chaffed. Also near the end of the harness near the firewall is a wear spot.
As was said, it is an important sensor affecting charge, AT shifting TC lock, cruise control and a couple other functions.
anonymous_1
13
04-30-2020 05:29 PM
BRUISER
02-02-2015 12:25 PM
stratos201proxl
01-16-2014 12:04 PM
Joey-D
12-12-2011 01:52 PM
77machomopar
07-15-2009 05:56 AM
