gear ratio
There's probably a tag fastened to the differential cover that identifies what's inside, but that's not totally reliable.
You can count turns of the pinion versus turns of a wheel. If it's a limited-slip differential design, I suppose that you need to have both wheels free to turn and the ratio of pinion to wheel revolutions equals the gear ratio (I'm not experienced with these limited-slip designs actually behave, though). If it's an open differential, you need to keep one wheel from turning while you do your experiment. The other will then turn backwards and at twice the normal rate. For example, if it's an open differential with 4.10 gears, just over two turns of the pinion would result in one turn of the free wheel. For good accuracy, turn the pinion enough times to get several turns of the wheel and do the math.
The nunber of teeth on the pinion and ring gear are usually stamped on the end of the pinion shaft that is threaded for the pinion nut, usually something like " 10 41 " meaning 10 teeth on the pinion, and 41 teeth on the ring gear, or a 4.10 ratio. Hope this helps. lol
accordionjohn
10-07-2002 12:54 PM
