Gasket prep
Gasket prep
I'm getting ready to install a new gasket from Cummins on the timing case cover. Any opinions on whether I need to prep the gasket and case/cover with something or just clean everything well and put the gasket on dry?
I use Permatex #2 on just the block side mainly to hold the gasket in place.
Don't know if this is the "recommended" way to do but it's always worked for me.
A trick that makes this job go easier is to get a couple of studs or cut the heads off a couple bolts the same size as the ones that hold the cover on, screw them in loosely.
They will help keep the cover and gasket lined up while installing.
aksparkey01
02-13-2008 01:04 AM
tomt
96
04-11-2003 05:43 PM
Stiffler
03-06-2003 10:49 AM
c5r
02-14-2003 05:08 PM
