fuel torque plate
yes i do have gauges How much difference is a 100 compared to a 10 plate Also a 100 is just the top of the 10 plate gride to a 0 plate also what is the advandge of going to a 100 instead of a 0 i am going to grind my plate
I have pics of both
In my gallery. The central difference is fueling, please look at the pics, the 100 is J shaped and is not as aggressive as the zero at full on defueling right away. itys a more gradual increase of fuel. The zero just has all out smoke and power at all times available on tap. With ur 370s though,215 pump, and 3K GSk, u might have too much fuel with the 100 or the zero for ur turbo though. Just watch ur egts and make sure u have good gauges, and ull be ok, If i was u, id slap the 100 in, the zero is just too much.. I know, ive ran them both.....
If u dont like to watch the pyro too much, and tow alot, the 10 is betteer for u, if ur truck is a to, id say the 100, But with either or, the 0 or 100 ur gonna need to watch that pyro when u hit the no defueling point...
Tx
Tx
it is probably due to the lever not hitting the plate properly...u have to check ur lever adjustment and adjust accordingly
http://www.piersdiesel.com/TechLeverAdj.htm
drolex
11-29-2006 08:56 AM
Rockcrawler
14
06-23-2005 11:40 AM
