fuel tank nut and gasket
are you refferring to the plastic collar that holds the sender in the tank? that'll be a dealer item or wrecking yard item. the oring or gasket will be a dealer item unless you can match a generis oring to it. wudnt buy a used one of those. i got luck at Pull-A-Part one time and found a collar for my daote lying in a truck bed. snatched it as soon as i seen it
Clane
06-02-2012 03:31 PM
Hercules
05-11-2010 12:51 AM
