fuel solonoid
fuel solonoid
Is there a fuse or relay that controls the fuel solonoid? I can energize it with a hot wire to make the truck run. However, I cannot get the truck to start without holding it up or energizing it manually. Thanks
Re:fuel solonoid
if it is the fuel shutoff soliniod to wich you are refering to then yes there is a relay on the fire wall wich 9 times out of ten is the problem. do a search and there should be more help on the subject.
Re:fuel solonoid
I had the sme problem on my 95 dually and I traced the wires as far as possible and it turns out there was a corrroded wire that was keeping it from gettin power. Might be worth checking out
Re:fuel solonoid
[quote author=dsljunkie link=board=16;threadid=10483;start=0#100395 date=1044382025]<br>I had the sme problem on my 95 dually and I traced the wires as far as possible and it turns out there was a corrroded wire that was keeping it from gettin power. Might be worth checking out <br>[/quote]<br><br>I had the same problem.<br><br>The Auto Shutoff Relay is the relay that controls the fuel solenoid. I would replace mine, have it work for a handfull of starts and then it would stop working again.<br><br>If this happens to you, check the blue power cable.
