Fuel Solenoid Cut off.....Where to get one cheeper?
www.fostertruck.com Check all his parts out for your truck as he is great to deal with and has some excellent parts. I might suggest to take it off and try cleaning it first and if the boot is trash make one out of some rubber, like a bicycle tube as suggested here by someone that has had good luck with making thier own, fosters also sells new boots, but by looking at it the bicycle tube would work.. Unless it has been burnt up electricly they can be cleaned. Goodluck,,Rick
I talked to Dave(i think?) at Foster Truck. Awesome dude! He talked me through some stuff and said that mainly its the relay if you can get the truck to run by manualy pulling on the shaft. So we are going to try the relay first and see where it takes us. Thanks much!
Dan
Dan
Robert, the blue link comes off the drivers side positive battery post clamp.
Not sure on the gauge, but on fusible links the color indicates the amperage rating. Pink- 30, Green- 40, Red- 50, Yellow- 60, Black- 80, Blue- 100.
All you need do is ask for the color fusible link you need at the auto parts.
