Fuel pressure under load?
I get 20 psi at idle, about 26 no load at 2500 rpm, and 20-21 at full throttle under load in gear. Does this sound right? When I pinch my return hose the pressure goes way up instantly, so I think the lift pump is healthy. Thanks
It's ok to dip below 25 psi for a short time under load such as when accelerating but for the most part it should stay above 25.
Make sure all your filters are clean and no lines are kinked.
Sometimes the lift pump will pass the pinch pressure test but doesn't meet the volume specs.
garyandbarb
08-15-2009 03:54 AM
blueberry
02-26-2007 04:40 PM
cumminsdriver635
17
12-01-2006 01:10 AM
Dodgezilla
02-13-2004 03:40 PM
