Fuel pressure questions
In a previous thread I started, my truck falls on its face at 3k rpms, even though I have a 4gsk. I replaced the overflow valve and replaced the pre-screen.
Today I hooked up a pressure guage and got the following results:
Idle 24psi.
No load @2000 rpm 24psi.
Under load (floored in 2nd) @ 3000 rpm 18psi.
When its under load and you lift on the throttle to shift, the pressure spikes at 30 psi for a second.
Am I correct in thinking the lift pump is bad? What should the fuel pressure be under load?
Thanks.
Idle 24psi.
Thanks.
Under load, 32-35. You need to pinch off the return line hose and see if your pressure shoots up to around 60, if it does, your LP is good and it is probably the overflow valve.
If it doesn't, replace the LP.
dodgeguy71
17
01-19-2012 12:52 AM
bigragu
01-24-2006 11:16 AM
mtl0727
11-05-2005 06:47 PM
darrenG
06-28-2005 07:43 AM
Flatty
01-05-2005 02:50 PM
