fuel pressure guage sending unit location
I have the prime loc system installed on my truck. It has two test ports where the filter mounts. I have been told one port is pre filter the other is post. Put the sending unit on the outside test port and am getting just under 25lbs. I am going to switch to the other port and see what i get. I hope the pressure will go up. If it does, i will know i am seeing the pressure pre-filter. This is probably the better of the two places. What do we think?
Im gonna switch it over to the other test port and see what happens. I agree that fuel pressure after the filter is what counts. If it stays at only 24psi max, then it might be time for a new lift pump. Im gonna change out the fuel lines just as soon as they show up. It might have a little bit of an air leak. I put on a new filter right after the guage install and it made no difference in fuel pressure.
Well, i pinched off the return line and the pressure did go up. It went up to just a little beyond 25lbs. like around 30 or so. So we think this might be a weak overflow valve? Im gonna pressurize the tank here pretty soon to check for leaks. Its gonna upset the wife if i buy an overflow valve, and then i tell her im gonna have to buy a lift pump. I have a holley blue i was gonna install. Ive been told that wont help anything. Let me know fellas!
Well, thats enough work to keep me busy. Would a bad lift pump cause it to lose prime? One in a while, it will either crank but not fire, or fire for a second and die. Its obiously not getting fuel. This is a relativly new phenominum.
My experence with this failure is that fuel tank level or parking the truck nose uphill can make the difference between a hard or easy start.
Jaxom
08-10-2013 11:05 AM
Southern Pride
05-18-2010 07:47 AM
cb06R1
10-17-2007 07:05 PM
