fuel pressure?????????
Old 04-12-2006 | 12:45 PM
Racing_Joe66's Avatar
what should the fuel pressure on the feed banjo bolt on the injector pump be at in idle??
stock pump
bumped pump
crusing down the highway at 60-65
stock pump
bumped pump
WOT
stock pump
bumped pump
i know this is the scale for 98.5 and up 24 valves but is this about the same for the 12 valves???
9-15 excellent pressure
4-9 weak pump or dirty filter
2-4 will run but rough need to replace pump
is this about right???????
thanks
Old 04-12-2006 | 05:56 PM
Willy91's Avatar
12 valves run a lot higher fuel preasure's than 24v's.
Old 04-12-2006 | 06:30 PM
there supposed to run like 17-22 psi at idle correct????? and about 25-30 psi at WOT with no load.
right??
thanks
Old 04-12-2006 | 07:23 PM
infidel's Avatar
Specifications are 17 - 22 psi at idle and 25 - 35 psi at 2500 rpm (no load).
dodgeguy71
17
01-19-2012 12:52 AM
bigragu
01-24-2006 11:16 AM
mtl0727
11-05-2005 06:47 PM
darrenG
06-28-2005 07:43 AM
Flatty
01-05-2005 02:50 PM
Quick Reply: fuel pressure?????????
