Fuel Plate questions.
Old 07-15-2008 | 01:01 AM
12valvesmoker's Avatar
Hi i'm looking on grinding my fuel plate down to a #100 or #0. Will this make my truck smoke a lot? I have my p-pump turned up also. Other than that my truck is stock. I would also like some pointers on how to grind the fuel plate down. Like videos or pictures. Thanks a lot.
Old 07-15-2008 | 07:37 AM
SHARPMACHINE's Avatar
The truck will smoke some, but only when you put your foot in it.
As far as pictures, you need to do some searching on here. This topic has been covered many, many times.
Old 07-15-2008 | 11:06 AM
12 flapper's Avatar
There is a diagram floating around here somewhere, I know that when you grind you want to smooth it out with some emery cloth when you are done.
I ground my own plates 100, 0, and 10. Its pretty easy. I hazed pretty good with the 10 plate with the 100 about mid way I can smoke pretty good.
Old 07-15-2008 | 12:42 PM
Mrlou's Avatar
#10 plate,with a boost elbow is awesome, smooth power, if you want smoke just turn afc wheel forward, it will smoke on command, cool. get an egt gauge asap. Also get a BHAF and 4 inch exhaust or at least cat and muffler delete, that will help keep the egt's down.
West Coast
07-01-2007 02:32 PM
plow
07-20-2005 08:40 PM
Rockcrawler
14
06-23-2005 11:40 AM
banks twinram
02-05-2005 10:38 AM
Quick Reply: Fuel Plate questions.
