fuel plate and gsk spring install problem
Ok so i installed my 3k gsk springs and my #10 fuel plate! ran it for a little and no smoke so i turned the star wheel towards the motor all the way and still no smoke! egt seem to go high quick and i am pushing about 35 psi of boost. Did i do something wrong? the truck runs like a champ and seems like it has good power more then it did before. I set the plate the same spot it was stock!
thanks
Eric
thanks
Eric
I got the gsk fro tnt diesel!
Yes i do have a pyro and boost and fuel pressure guage!
I thought this thing should be blowing smoke! but it is not!
T toke it for a good ride and got into it a couple times and the pyro guage never went pass 9.5! and tha was pushing it hard real hard when it got that high!
So how much more should i move the afc forward? all the way? what should the normal egt be when crusing done the road at 65mph? It runs pretty good now i dont want to make the the darn thing eat my clutch? also does any one have a good write up of how the ip works?
600-700° while cruising
Your clutch won't last if stock.
Check this> http://www.pdrdiesel.com/oldsite/TechLeverAdj.htm
IP links
http://dieseldatabase.com/read.php?id=58
http://dodgeram.org/support_pgs/diesel_ix.htm
My 95 sees 600 deg pyro at 65 mph and 1100 temps with the petal down. The 10 plate is in the stock position and I have installed the 3000 gs. I have never had the pyro go over 1100 towing my fiver. I have given some thought to moving the 10 plate forward some to see what happens, just have to get time to get at it . Truck pulls nice , not a race truck but no were near as laze as stock was.
mybajadodgeram
03-30-2012 10:41 AM
halfpint23
07-27-2007 09:13 PM
Dave88LX
02-12-2006 11:29 PM
big green
05-13-2005 07:21 PM
