Fuel plate/brass fitting
That brass fitting if it looks like this.
That fitting is very important as it is for wastegate control on your turbo. That increases your boost to 35 psi from the stock 21 psi and dramatically reduces EGT from the increased fuel of the plate. That is the issue I have with any of the EBay plates out there is that your are missing this $25 item that could save you on EGT and let you get full power of the plate.
With the H1C and HX35 turbos they have been reliable up to 35-36 psi (typically the set point for the boost elbow). At 33 psi should be good all day long.
89dieselkong
12-18-2010 07:14 AM
barngal6
02-07-2009 06:21 PM
sallyman1
19
01-17-2008 09:35 PM
