Fuel lines from tank.
Old 10-01-2016 | 11:00 PM
73CrewCab's Avatar
I have a 95 donor that I'm using for my CrewCab swap, and my fuel lines from the tank to the motor are both too short AND rusty. Can I just use the same sized steel/aluminum tubing, with rubber hoses and standard hose clamps at the ends, or I need to go to the dealer and order new suction and return line assemblies? Are they the same as a gas truck (maybe the V10)? I've seen a few V10's, a lot of V8's and zero Cummins trucks in the junkyards.
Old 10-02-2016 | 12:32 PM
gorms's Avatar
Nothing fancy is required, lots of guys have used marine rated hose for supply and return, tank to pump, with good results. Stock is 3/8 supply, 5/16 return.
Old 10-02-2016 | 07:43 PM
73CrewCab's Avatar
Just what I needed to hear. Thanks!
Stamey
06-27-2008 02:04 PM
93Fury
05-20-2008 09:24 PM
DrBob
08-14-2007 11:30 AM
Timberman
16
09-04-2005 02:39 AM
MrKen
02-25-2005 04:22 AM
Quick Reply: Fuel lines from tank.
