Fuel Lines
Old 06-27-2003 | 11:52 PM
Cowboy73's Avatar
Fuel Lines
Just found this site earlier this week. Lots of great info and knowledgable folks on here. <br><br>My question is: I just replaced my supply and return fuel lines on my 97 2500 (220,000 miles), do I need to bleed the high pressure lines? I cracked the low pressure fitting on the filter and hit the hand pump a few times to clear it out. The truck started right up so I'm not real concerned, but just curious because the Dodge manual does suggest bleeding the system whenever you work on it.<br><br>I'm chasing down a low power condition that only shows up when I'm towing....<br><br>Thanks for any and all replies!
Old 06-28-2003 | 04:09 PM
bulthisl's Avatar
Re:Fuel Lines
Nope your good to go. ;D<br><br>what's the power loss that your talkin about?<br><br><br> : Eddie : 8)
Old 06-29-2003 | 09:11 AM
Smokee's Avatar
Re:Fuel Lines
I am not sure about your bombs, Cowboy, but here are a couple suggestions: first, of course, check the filter. Next, check the linkage on the wastegate. If the line from the AFC to the turbo is rubber, you might try pinching it off.<br><br>Also, one thing that happened to my truck that resulted in low towing power was that the stock fuel plate ws not installed straight. The slight &quot;cocking&quot; of the plate meant that everything was smooth, the boost was about right, and all was well unloaded, but as soon as the truck needed more fuel to pull, the boost would drop to about 10, and I couldn't get over about 65mph towing into the wind. <br>good luck<br>george
Old 06-29-2003 | 12:07 PM
Cowboy73's Avatar
Re:Fuel Lines
The fuel filter has about 6k on it, but I will change it and see if that helps. Will also check the wastegate.<br><br>My engine is completely stock. The only upgrades are an AFE filter and 4in. exhaust. It runs fine unloaded, but when I tow and hit a hill, no power...lose speed but the rpm's stay up. I used to be able to tow the Cascade passes here in the northwest at 60-65mph. Took the trailer (8000#) out last week and creeped over at 35mph and overheating. I'm putting in a new fan clutch and thermastat that will hopefully solve the overheat condition. One other note....believe it or not, I am still running the stock auto trans with 220,000 miles on it. I'm sure that's part of the problem.
Old 06-29-2003 | 08:52 PM
JFellman's Avatar
Re:Fuel Lines
&quot;and hit a hill, no power...lose speed but the rpm's stay up. &quot;
You're slippin! Lucky you...you get to get an aftermarket trans now...
Old 06-30-2003 | 06:28 AM
Smokee's Avatar
Re:Fuel Lines
YEP. The tranny is slipping. It will get worse. I redid my tranny for an ATS setup at...220,000 miles...perhaps that is the magic number?<br>george
Old 07-03-2003 | 11:50 AM
Cowboy73's Avatar
Re:Fuel Lines
Well, I solved the overheat problem and am scheduled on the 21st to get DTT'd....the full package. ;D ;D
Old 07-03-2003 | 06:38 PM
JFellman's Avatar
Re:Fuel Lines
Man, I sure envy you, Cowboy....I'm wantin a DTT fix in the worst way, but can't justify it until my slushbox starts slippin. Guess I'll just get some 370s to take care of that! ;D
You need to join us at the Northwest Bombers website
Old 07-05-2003 | 07:47 AM
turbo thom's Avatar
Re:Fuel Lines
John was right and I'm glad you went the way you did. The tranny was &quot;all&quot; you trouble. Probably the heat thing too.<br><br>..Preston..
Old 07-09-2003 | 01:34 PM
Cowboy73's Avatar
Re:Fuel Lines
Yep...I suspect the tranny was a major contributor to the heating problem. I did replace the thermastat with the one that stops the constant temp cycling. It's nice to drive down the road and see the thing stay at a stable temp. <br><br>Now if the 21st would hurry up and get here, I can get that new tranny put in. ;D<br><br>Thanks for all the replies. And thanks to John for the tip on the Northwest bombers site, I'll check it out!
billmac
0
03-20-2006 03:03 PM
chucktownsend5
03-08-2005 08:21 PM
MrKen
02-25-2005 04:22 AM
debolton
24
06-29-2004 09:22 PM
hellotbone
09-01-2003 08:46 PM
Quick Reply: Fuel Lines
