Fuel leak
Fuel leak
I am leaking fuel at the tank....looks like the push lock connector for the return line is buggered....the blue piece in the connector is broken.
I am going to NAPA tonite.....I believe the return line is 5/16 hose?? about 12 feet do it??
Is there such a thing as rebuild parts for the quick connect?? its just not hooking up because, I think the plastic clip is buggered.
25 degrees and snow on the ground.....looking forward to this. not.
Don
Don
is there a pic of this? I dont understand how to pull the quick disconnect off. I have not done this yet, so have not experienced this part. Is it really just pull? or is there something else to it. Thanks, ken
I just mangle the quick connects off with a pair of pliers by smashing them.
This picture is of the newer style with plastic tubes.
This picture is with a Draw Straw kit from Vulcan Performance used when the tubes are rusted out
Well, got the parts , 10' of diesel rated hose,clamps etc.
Plan is to cut the rubber hose going to the sending unit, splice in about 6" of new hose and put a clamp on the stem. I had to put a new sending unit in Christmas a year ago because the steel stem had rusted out....thats probably how I mangled the connector...man you talk about a night mare, dropping the tank in the driveway, in the dark, 35 degrees and raining, half assed tools,in Christmas eve, oh I was 300 miles from home.
Got to do a quick fix, and when the weather breaks I will run rubber on both lines.
well ...done.....cutoff the quick connect junk, ran 5/16 right to the draw straw and spliced into the old hose....took about 20 minutes....job not perfect but nolo leako. when I see some warm weather....will replace all fuel linwa w/ rubber. out.
ZPOD
18
09-23-2010 10:37 AM
superdiesel9
10-25-2009 07:56 PM
donhov
26
01-06-2006 07:29 PM
Lightman
16
01-21-2004 10:46 PM
