Fuel Leak
Fuel Leak
I just bought a 96. It was stock when I got it and has never been touched. I put a zero plate in and a set of 215's that I had laying around. One of my banjo washers was leaking so I replaced them all and I noticed that I was leaking fuel. I figured it was just from the banjo bolt washer so degreased the engine and checked later and it is still leaking fuel. I got under the truck and looked and it is dripping from my bell housing and it looks like it is coming from above the starter. Probably my return line? It didn't leak before I swapped injectors. Is it bad timing or did changing my injectors have aything to do with it?
Where you describe I would guess return line. There is a connection on the bellhousing where it goes into steel braided if I remember right.
Lots of threads here about replacing the lines back to the tank.
Well after looking closer I think that it is oil that it is leaking.. I just replaced the valve cover gaskets and since #6 is kinda of a pain I was thinking that it might be leaking so I replaced and it seems to still be leaking. Any ideas on that?
ZPOD
18
09-23-2010 10:37 AM
superdiesel9
10-25-2009 07:56 PM
donhov
26
01-06-2006 07:29 PM
Lightman
16
01-21-2004 10:46 PM
