Front driveshaft yoke (if thats what its called) seal on xfer case...
yea, I think u just unbolt that rear housing and it should be right there when u pull the case off. I have to tear mine apart for my swap but I really have no clue what i'm doing, lol.
You don't have to pull the case apart to change the front seal. Pull the driveshaft and you'll see a nut holding the yoke on. Take the nut off AND THROW IT AWAY. They're only good for one time. Trust me, been there, done that, twice. There's a special rubber washer under the nut that need replacing as well.
..on my '94 I replaced all seals frt to rear.On the transfer case "Front seal" ...My Experience with the chrysler OEM one was, it was superseeded or the partsman gave me the wrong one..It was missing the nice wide "Flange" like the oem one I took off..NAPA .(brand name NSK I think) has the nice wide flange one..the'use it once' nut cost about $11.00 -+ ..at the dealer only..I tried removing the seal with what ever I had ..screwdriver,long punch..I finally had to buy a "Seal" removel tool for about $16.00 .It worked "Choice"..it looks like a "miners Pick" with the picks on both ends facing down..recommended. those buggers can be in there tight...good luck
NAPA's site:
http://www.napaautoparts.com/masterp...Seal&VehCode=Y
NAPA's site:
schamran
01-15-2012 09:12 PM
