Front Axle U joints
Front Axle U joints
While doing a brake/rotor job on my truck I noticed both U-Joints are a bit noisy/squeaky and need to be replaced.
Can anyone give me a simple easy to follow procedure to change these? Also, what is required as far as axle seals, etc?
Thanks
Thanks
Re: Front Axle U joints
Originally posted by Bobcat698
...simple easy...
...simple easy...
Here's the steps in a nut shell:
1) Remove wheel and hang caliper from the spring or frame via wire, remove any ABS wires, etc...
2) Remove large nut holding axle onto hub.
3) Loosen 4 12-point cap screws on back of knuckle holding hub to knuckle. Tap on each cap screw in a cross pattern to drive the hub off of the knuckle.
4) When the hub is finally loose, remove cap screw, support axle as not to damage the seal and remove hub.
5) Axle pulls out.
Check your ball joints while your at it. Your almost there if they need to be changed. You don't need seals as long as your careful removing and re-installing the axle. It will drip a bit after your done as the tube will have lube in it after the seal position - clean it out as best you can with a rag prior to putting it back together.
I already had the hubs off.. It wasn't hard at all once I got the calipers off..
I don't know the exact procedure to change the u joints, but I did gently remove the axles with no fluid seepage.
...I don't know the exact procedure to change the u joints...
Hummin Cummins
04-13-2008 04:35 PM
Joe Diesel
23
03-25-2008 07:39 AM
