Free spin hub kit (stripped bolt in diff carrier!)
Well started the install of the hub kit I received from EMS Offroad today. I got the inner and outer axle shafts, spindles, etc... Everything went well until I got to the differential. I manage to strip out the pin that holds the pinion shaft the in place. It is recessed about .5" inside carrier. Tried everything including breaking off a torx inside.
Anyways very easy install but there is always little hang ups.
Any ideas on how to get the bolt out.
So far bout 5 hrs. invested. Including put just the spindles on so I could craw home for the night.
I can not weld a bolt or nut to it it is in a hole imagine counter sunk.. around .5" tried to drill it out but no luck thinking about taking to a machine shop here pretty quick no more ideas left.
Do you have access to a welding torch? Maybe heat the surrounding area enough to expand it and get the nut out.
If youve got a torx head broken off in there thats going to be a problem since tool steel is pretty hard.
Ive got a few ideas but none of them would be as good as taking it to a machinist. =(
ThSimpson
11-29-2009 05:27 PM
ThSimpson
11-29-2009 02:53 PM
bc3
18
05-07-2008 06:06 AM
IL Ram
12-22-2007 05:51 PM
