found a doner truck (for the motor)
Old 09-16-2009 | 08:28 PM
diezel freak's Avatar
i have finially found part of the problem with #3 knocking. i bit the bullet and pulled the head. and found that all 6 pistons were melted so i found a bone stock 95 3/4 ton 2wd with 126000miles and a bad slushbox the old timer pasted away and the wife said that he hardley went over 55mph so i think it is a great motor and he bought the truck new. am i going to have any probs mating nv4500 to it? besides having to put my fly wheel and bell housing on it. my plan is to put this motor in my truck for the time being and take my time rebuilding the bad motor. what do yall think?
Old 09-16-2009 | 08:31 PM
Totallyrad's Avatar
If you're going to build yours, why do the swap. Drive the running truck and fix yours, save the extra work of doing the engine swap.
Old 09-16-2009 | 08:34 PM
Clarkkent's Avatar
you missed the part where he said 'bad slushbox" but the tranny may be an easy fix. all hydro, no computer...
Old 09-16-2009 | 08:42 PM
Totallyrad's Avatar
Yep, CRS.
Old 09-16-2009 | 08:44 PM
i need my dually. i pull a gooseneck flat bed on a regular basis loaded with round bales or tractors. a 3/4ton wouldnt cut it
Old 09-16-2009 | 08:54 PM
Totallyrad's Avatar
Roger that, I don't blame you. I upgraded from a 2500 to a 3500 dually when I bought my last one, same reason. My loads were increasing and I wasn't feeling warm and fuzzy any longer with just one tire on each side.
Old 09-16-2009 | 09:08 PM
the best part about the doner truck is i am giving just under $1000 for it... tho i have one other Q: r the starters the same between an A/T and M/T?
Old 09-16-2009 | 09:24 PM
Totallyrad's Avatar
Wow!!! That's a great price. If the body is good it'd be worth fixing the tranny just to have. I thought I saw a 2nd gen auto in the classifieds recently. As to the starter, I don't know. I went from 1st to 3rd gen, missed the seconds all together.
Old 09-16-2009 | 09:50 PM
ttcfan4476's Avatar
the starters are the same just put my third one in
Old 09-17-2009 | 06:06 PM
RPegram's Avatar
You should pass on this deal and run extremely fast in the other direction. It is a bad, bad, deal. While you are running, would you mind sending me the information on truck (telephone number, location, address, things like that).
Old 09-18-2009 | 03:51 PM
Tate's Avatar
The engine adapters are the same as well. The only real difference is there will be a TPS sensor on the throttle linkage for the tranny.
Hang onto that 2wd truck, could make it into a nice little cruiser.
blackram2500
04-29-2010 04:36 PM
whosdunit
04-06-2010 09:06 AM
DodgemnLeavem
01-20-2010 10:25 PM
NO_SPRK
11-22-2009 05:19 PM
Quick Reply: found a doner truck (for the motor)
