Found a 98 12V, doin KDP and...???
Old 02-20-2009 | 10:00 PM
RaiderRedRam's Avatar
My search for a 98 12V is over and it is on the way. I found one that is pretty much stock other than a muffler delete.
I'm looking for your input on first mods. I'm planning to do the KDP and a few others, nothing to wild. I know I've got a PS leak to deal with once I find the source. It will be my new daily driver with occasional towing between 8 and 12000 lbs. I got it bought right so I have a limited budget to make a few changes, but can't get too carried away.
Let me know your thoughts on where to start.
Old 02-20-2009 | 10:14 PM
Swarthy Dago's Avatar
change the control arms with good heavy tube steel type (like Rancho) and urethane bushings, maybe add a steering box -pitman arm bearing mount, get rid of the air filter with a BHAF, get good gauges, boost, exhaust, trans temp, fuel pressure, mod the inj.pump with a different plate, get good filters, lots of good stuff on these threads.
Old 02-20-2009 | 10:28 PM
Definately planning on more air - either AFE or BHAF...
Your recomendation on quality guages for a good price? Glow shift, autometer, Pricol, Isspro?
Also, what would be a good plate for my stock auto trans and TC?
Old 02-21-2009 | 12:28 AM
wcbcruzer's Avatar
Once the truck is running like it should, these are the must do mods imo:
1) Gauges (at least boost and EGT)
2) Valve body
3) Low-stall single disc billet torque converter
4) #10 plate
5) 3kgsk
Then:
6) BHAF
7) 4" exhaust
8) Steering stabilizer brace
If you need a track bar (common wear) you can either get a Luke's link, Thuren heavy duty, 3rd gen conversion, or lifetime warranty one from autoparts store.
I know the TC and valvebody is kind of expensive, but it needs to be done. I can't believe I used to drive with the slushy stock torque converter that was designed for a gasser. How I put up with it for so long I don't know...
Old 02-21-2009 | 12:56 AM
Eat Beef's Avatar
From: Alberta Foothills - Power to grow with 6 in a row - XLR8
Get it breathing GOOD first. Then look after the rest.
Old 02-21-2009 | 07:56 AM
Common's Avatar
2) Valve body
4) #10 plate
5) 3kgsk
Then:
6) BHAF
7) 4" exhaust
Sorry man, gotta disagree here.
Getting it to breathe better is first in my book.
First Mods: (In Order)
1. BHAF. (Or your choice of intake)
2. 4" or larger exhaust.
3. EGT, EGT, EGT, EGT Gauge!!!
4. Boost and/or Trans Temp Gauge.
5. #10 Plate + Boost Elbow.
Then I'd stop and see what else you might want.
Old 02-21-2009 | 08:36 AM
Great input and I appreciate it!
A few questions though.
What is involved in a 3rd gen track bar conversion and is it better/cheaper than the aftermarket ones mentioned?
What would be a good choice for the $ on TC and valve body upgrade?
Boost elbow? I know what a boost fooler is on a 3rd gen, but unfamiliar with 2nd gens so help me out here.
What do the BHAFs usually run and how many miles do you get from one? I'm in a dry dusty climate.
Old 02-21-2009 | 08:07 PM
JohnX's Avatar
My thoughts...
Air filter
4" exhaust
gauges (I have glowshift and think they are great for the price)
Trans upgrades (VB and TC)
Fuel plate
3k gsk
Old 02-21-2009 | 08:18 PM
Originally Posted by JohnX
My thoughts...
Air filter
4" exhaust
Fuel plate
3k gsk
Thanks JohnX. I was wondering if anyone around here had tried the glowshift, can't beat the price, just curious how accurate they were compared to others.
Old 02-21-2009 | 08:22 PM
wcbcruzer's Avatar
I'm sure Glowshift makes decent gauges, but for EGT I wouldn't feel comfortable having anything other than Autometer or some other well-known brand that racers use.
Old 02-21-2009 | 08:46 PM
Tate's Avatar
The way I modded my truck was this.
BHAF
Gauges
Plate
GSK
clutch
injectors
turbo and exhaust
EGT's were quite low for just a 3" straight pipe. I don't think its a huge deal which way you go with it, eventaully, it all gets done.
caper
05-13-2014 05:20 PM
Smokin96_12v
10-12-2009 07:39 AM
HOHN
02-21-2005 07:36 PM
Buzz
04-01-2004 10:48 PM
steveb
45
04-23-2003 01:37 PM
Quick Reply: Found a 98 12V, doin KDP and...???
