Ford cummins swap
Old 09-24-2012 | 12:54 PM
12valvewagon91's Avatar
Ford cummins swap
I have a customer who has a VERY solid 76 3/4 ton ford high boy. He want to put a cummins in it.
I have an adapter plate that was on my 4bt cummins. Will that adapter plate work on his tranny? He has a 360 big block in the truck now, and he wants me to put 3:08 gears in his ford to keep his tranny and divorsed t case. DONT ASK ME WHY!! He has a nice 93 dodge with a getrag in it that just needs rebuilt.
So I guess will the flywheel and adapter I have work on his ford tranny?
If not is there a company who sells the adapter?
Thanks guys
Old 09-24-2012 | 04:51 PM
patdaly's Avatar
Is it the 4BT Ford adapter?
I know, but I had to ask. If so, yep, should bolt right up, BUT I would do a NV4500 2WD swap to get that extra gear.
Old 09-24-2012 | 05:37 PM
kujo's Avatar
fords are odd, they have a few different bellhousing bolt patterns, windsors wont bolt to a big block tranny, and they had a few different breeds of big blocks and i am not sure if they are all the same patten or not..
Old 09-24-2012 | 07:35 PM
patdaly's Avatar
DOH! Should have kept my mouth shut, kujo is correct, FE is by itself.
http://www.wilcap.com/tech.html
Oh well, Dodge adapters and bellhousings are cheaper by far than the Ford adapter.
Good reason to forget the gear swap and just put a 5 speed in.
Old 10-03-2012 | 10:11 AM
i think he found another truck. so he can run the t case, and tranny out of it and it will mate with his Ford drivers side front axle.
Saving him cash in the long run.
Old 10-03-2012 | 10:59 AM
joem's Avatar
A friend of mine has a rare VP44 (its actually a cummins style electric fuel system that looks like a vp44) 12 valve and a AT545 stuffed into a gas 1988 F350 with 355 gears. Pretty nice ride and one heck of a rare engine
Old 10-03-2012 | 01:45 PM
What did that engine come out of?
Old 10-03-2012 | 10:55 PM
joem's Avatar
90's school bus
Old 10-12-2012 | 02:03 PM
marder's Avatar
http://www.4btswaps.com/forum/forum.php
Tons of info and part sources here. I had a 4bt with a Ford tranny. I think it only works with a mid 90s half ton 5 speeds. Check that site they will get you in the right direction.
Pele
Cummins Conversions
05-21-2014 06:49 AM
Marty86
09-11-2007 03:56 PM
Cummins Freak
01-10-2007 01:11 AM
4doogie
12-26-2006 05:37 AM
thumper 549
01-02-2005 04:49 PM
Quick Reply: Ford cummins swap
