Flushing antifreeze
Old 06-19-2007 | 08:43 AM
turbo246's Avatar
Flushing antifreeze
This weekend I want to drain the radiator and put some new antifreeze in just because it hasnt been done in a while. Do I need to add any additive to the coolant so it doesnt bubble from all the vibration, I had heard you have to do that on Ford's from vibration and CTD vibrate just as much if not more...the trucks a 95 12 valve thanks
Old 06-19-2007 | 12:39 PM
atc250r's Avatar
I don't know about additives but you should use distilled water rather than tap water to avoid scale build up. Also, be aware that there will be almost 5 gallons coming out of the radiator drain valve. I just drained mine into a 5 gallon spackle bucket the other day and it came up about 4 inches from the top.
John
dodgediesel
09-23-2007 03:27 AM
ckennedy
33
05-21-2007 01:45 PM
D.S.
03-10-2006 08:39 AM
apache
05-18-2005 07:58 PM
Rayzor
08-19-2003 07:52 AM
Quick Reply: Flushing antifreeze
