First post and a Question
Old 12-21-2002 | 07:49 AM
blackholehunter's Avatar
I just found this site yesterday and figured I'd join and see what the place was all about. My truck has a K&N air filter on it and I am looking to replace it with a filter that is basically on open element style that wouldn't be in the airbox. Does anyone make a kit that comes with new inlet piping for the turbo. Or, is it something I will have to fab myself. I have seen the Old Smokey BHAF mount on the TDR but, I would prefer a non-enclosed setup. Basically, I just want to hear the turbo. I rode in a 98 that had a filter setup like this and I fell in love with the way it sounded. Thanx for any help!
Old 12-21-2002 | 08:19 AM
Monty's Avatar
Re:First post and a Question
If your airbox is like mine, and I think It is. Just take the airbox out of your truck and only use the faceplate and rod that mounts the filter to the hose. You can use your existing K&N that you have now for this. I ran mine like that for a long time and many other first gens on here are too. I have just recently switched to the RE-0880 K&N open element.
Old 12-21-2002 | 09:13 AM
richard's Avatar
If you would like more turbo noise, you could also take the silencer ring out of the inlet side of the turbo. I am not sure if your truck has one, but if it does, after removal you will hear a little more turbo ;D ;D
Old 12-21-2002 | 09:19 AM
Monty's Avatar
Wish it was that easy, but the 1st gens with the H1C turbo do not have a silencer ring. Also, one of the reasons why a 2nd gen trucks turbo is so much louder is the mounting location of the filter. Ours on the 1st gen are down by the pass.side of the radiator.
Old 12-21-2002 | 09:22 AM
richard's Avatar
See that, you learn something new every day.
Old 12-21-2002 | 09:41 AM
Bob Beauchaine's Avatar
I am currently running an Old Smokey BHAF mount with a K&amp;N - you can hear the turbo quite well and it does breath better. I put it on about the time I did my last oil change so I will have to wait for an oil analysis to see how well it works. Inspection of the intake show no deposits. ;D ;D<br>Bob
Old 12-21-2002 | 11:44 AM
Stevie G's Avatar
I am running the K&amp;N in a modified factory airbox.<br>The turbo screams, especially with an open exhaust and turned up pump.<br>http://www.swampfoxcustoms.com/airbox.JPG<br>I used a rotary tool to open up the side of the box and then made the panels from fiberglass to go to the back of the headlight valance.
Old 12-22-2002 | 01:06 AM
[quote author=OkieBroncRider link=board=16;threadid=8615;start=0#83193 date=1040480349]<br>If your airbox is like mine, and I think It is. Just take the airbox out of your truck and only use the faceplate and rod that mounts the filter to the hose. You can use your existing K&amp;N that you have now for this. I ran mine like that for a long time and many other first gens on here are too. I have just recently switched to the RE-0880 K&amp;N open element.<br>[/quote]<br><br>I was curious if that would work. I'll have to go out and give it a try. Thanks for the quick response guys!
Old 12-22-2002 | 06:22 PM
dsljunkie's Avatar
On my 97 i just cut out several 1 inch holes evenly spaced on the side of the airbox with a rotary tool. I have a K&amp;N and I can definately hear the turbo. Your setup sounds similar to mine and its not hard to do. might wanna give it a shot.
Old 12-23-2002 | 04:36 PM
Lil Dog's Avatar
As Okie said the 1st gens have different filter canisters. In our rigs the we have drum air filters (much better than brick IMHO) stock and it is upfront behind the headlights. The Ol Smokey setup is pretty trick, I'v been lookin at that one as my 93 doesn't have the center bolt to hold the filter on so, I can't just go open element. &gt;<br><br>Ah well, We'll figure somethin out.. Might have to go to the wreckers for a 92 intake pipe..<br><br>Hey Okie how did you mount the RE 0880 in your fender? Courious as Scotty and I were wrestling with how to make a system for the first gens...<br><br>J-eh
mikem74
Introductions / New People
04-11-2010 09:03 PM
exwrestler
06-04-2009 03:19 AM
mw66nova
07-22-2007 08:30 PM
saleencobra
04-11-2007 03:47 PM
cardinal fang
15
01-09-2007 10:22 PM
Quick Reply: First post and a Question
