Fire ring install
Old 04-12-2004 | 04:10 PM
southernsmoker's Avatar
Fire ring install
When I am installing fire rings with the head only cut, all I do is put the gasket on the block and set the rings inside of the gasket fire rings.....right? Every thing should line up as long as the head is cut right shouldn't it?
Old 04-14-2004 | 02:44 AM
PourinDiesel's Avatar
Call or www.haisleymachine.com
--Justin
Old 04-14-2004 | 03:05 AM
Battering Ram's Avatar
Thats a dern good question... when I did mine I did grooves in the head and the block so it was easy to line mine up perfectly... all I had to do was set them in the groves. I'm not shure how you would make shure that the fire rings set in good with the head as you lower it on the block. You might want to give Haisleys a call and see what they suggest. I would definantly not just guestimate and set the rings on the block inside the gasket and hope for the best.
Horace
gecoveyc
07-20-2010 12:02 PM
Caterpillartim
37
03-17-2008 04:08 PM
gotsmoke6
07-18-2007 08:05 PM
98.5POS
37
01-26-2007 08:26 AM
HaulinBut
05-12-2006 03:06 PM
Quick Reply: Fire ring install
