Fan will not come off
Old 10-22-2005 | 07:28 PM
Greguw's Avatar
Smile bearing block ...
I wonder if anyone ever had to buy one ... I have 2 cummins service centers near me .
I got the KDP done today , I also managed to do the seal on my vacume pump ... with the timing cover off it made it a little easyer .
I have to change the oil tomarrow and make up my parts list ... any one think I will have a problem moving it around with out coolant ... I cant put the belt on til I get that block .
Thanks Guys
Greg
Old 10-22-2005 | 09:40 PM
Dshiftff's Avatar
Ive heard a few say the cooling system is so good with the cummins you can run without a fan. food for thought
Old 10-22-2005 | 11:01 PM
mikal711's Avatar
i just changed my fan clutch pull to passenger side with wrench it came off easy , changed it in 15 mins from the bottom
Old 10-22-2005 | 11:03 PM
mikal711's Avatar
by the way the dang clutch is 309.00, my ac would not cool at idle
Old 10-23-2005 | 12:31 AM
infidel's Avatar
Wow!
For a 12 valve they are only about $60
Old 12-28-2011 | 06:21 PM
Nubby55's Avatar
Well I just changed the bearing on the pull it's self. every body said it's left hand tread to remove the fan, I even got the puller wrench set, it still would not come off. I pulled the whole bracket fan and all, put the pulley in the vice with blocks, won't turn loose, put heat on it, still no go. I totaled the pulley, THEN I tried to turn it counter clockwise [the way you would break a right hand tread lose] and it came right off. On my 2004,5.9 the treads are RIGHT HAND!
redsealdodge
31
12-07-2007 05:22 PM
deiseldog78
11-17-2007 07:38 PM
big jimmy
07-07-2006 01:33 PM
Quick Reply: Fan will not come off
