extended crank, hard starting
OK, It has been doing this ever since I installed the 1997 180 horse 12v (155k) in my truck. mods include a 100 fuel plate, tightened govenor springs, fuel plate and AFC slid forward, and an h1e/16 hybrid tubo. When I start my truck, and I mean whenever, not under a particular circumstance, I have to pump the pedal while cranking in order to get it started. It only takes one pump, and it fires right up, however, if I dont pump the gas, I can crank for two days and it wont start. Also, when it gets cold out, maybe below 40, it doesn't stay running if I don't keep the RPMs up, and it blows a TON of white smoke. The truck runs perfect otherwise, and has plenty of power. I can tickle 40 lbs of boost on a 0-60 run. It does get considerably worse milage than my VE motor did. I used to get around 20, and now I average 15, If that is any clue.
Nothing is wrong.
The P-pump is based on WWII technology, there is no computer to give it a little fuel when starting.
You can either turn the idle up or get used to giving it a little pedal.
Personally I prefer giving a little pedal.
Think if you flip your sun visor down it even says to give it a little fuel when starting.
I know my 94 had a problem with that. The suction line to the lift pump developed an air leak (you can't / won't see it, it's suction). I think there is also some sort of drain-back check valve somewhere.
Nothing is wrong.
ramsport59
0
09-03-2007 08:07 PM
abc4yew
03-15-2007 11:55 PM
