Exploded View Of A P Pump
Can Anyone Post Up Or Put Up A Link To A Exploded View Of A P Series Pump. Also Looking For Pictures Of Fuel Plate Adjustment And Star Wheel Adjustment Anything Will Be Appreciated Thanks In Advance
DTR question asker
If you go to my gallery you'll find a list of names/part numbers that go with this diagram.
https://www.dieseltruckresource.com/...4&ppuser=25501
Governor section
Governor section
So The Way It Looks From The Cut Away Pic Is That You Take Out That Plug And Use A Screw Driver To Turn The Star Wheel Counter Clockwise Like A Drum Brake Adjuster Am I Correct?
I saw a pump cracked like that but not near as bad after the timing case cracked from a loose KDP and the owner JB Welded the crack.
What happened is without the KDP and decreased structural integrity of the case the timing case broke totally in half. Nothing left to hold the injection pump in place but the lines, linkage, etc, which were also mangled.
