engine stalls just after startup
Old 12-23-2011, 04:26 PM
infidel's Avatar
Easiest way to find fuel system leaks is to pressurize the fuel tank to 10 psi max then go hunting.
I use an old fuel cap with an air chuck tapped in but a blow gun wrapped in a rag works also except then it takes another person to do the hunting.
Only leak this won't find is if it's inside the fuel tank which does happen.
Good reading> http://www.cumminsforum.com/forum/94...m-writeup.html
Old 12-23-2011, 09:55 PM
GCSS's Avatar
Originally Posted by 9812vram
I'm thinking he means the one in red.
wow...neat diagram...thankyou!
so.....if the line visually looks to be OK, should I replace it anyways???
Old 12-23-2011, 10:18 PM
torquefan's Avatar
Might not be a bad idea. You might see a wet spot on it somewhere, or if you flex it in your hands, you might see some cracks open up. I've seen it on many 2nd gens, so it's worth throwing one on as a preventive measure. The return hose is 5/16" diameter, and I think around 18" long.
Old 12-24-2011, 12:03 PM
GCSS's Avatar
OK...
I think I will change it out. Thanks for the info on sizes
Geico266
22
11-23-2012 09:43 PM
l jobb
01-31-2008 10:27 AM
Lark
02-27-2007 05:32 PM
Hounddog
02-14-2006 06:33 PM
MIKE,J
08-29-2003 09:26 AM
Quick Reply: engine stalls just after startup
