Engine Oil Leak
Engine Oil Leak
just bought a 95 3500 4x4 with 86,000 miles. has a oil leak in the front of the motor. does not seem to be the front crank seal. looks to me like it is from the timing cover area if front or the injector pump. i need to degrease the complete area and see if i can pinpoint it. it almost looks like it could be from the timing cover gasket. i did not think that that was a common leak area. any ideas? what kind of job is it if i have to pull the cover? thanks.
Originally posted by CarlJensen
Degrease and spray with aerosal foot powder to find the oil track. Has the KDP been taken care of?
You shouldn't have a killer dowel pin (kdp) problem, that was taken care of by the time the 2002's came out. If you do a search there is plenty of reading on the subject though. You probably just have a seal leaking.
Check all the case bolts for tightness. I had a pretty good leak from the front and ALL of my bolts were very loose. Some I could turn by hand. Snugged them all up and oil leak was gone. Also check your pan bolts. Most of mine had worked loose too.
My 95 pin had worked out about 1/16 or so and it was a relief to know I caught it it time to prevent damage. The pin is behind the front case cover and is not hard to take care of. Do a search on KDP and get all the info you need. Also a chance to check all the other bolts in there for proper torque.
Put a new seal in at the same time.
Originally posted by nitrousn
whats the kdp? and how will i know if it has been done?
The only real way to know if it's been taken care of is to remove the timing case cover, be prepared to contain the pin as getting the cover off is the hard part by far.
Typical damage below, this crack is always hidden under the fan pulley
george7941
11-28-2009 09:28 PM
donhov
26
01-06-2006 07:29 PM
johnshole
21
04-04-2004 04:23 PM
