EGT temp difference?
I know the directions are to install the temp probe into the rear chamber before the turbo. On my Excursion in my sig I could not get a drill to the rear one so I put my EGT probe into the front chamber before the turbo. My truck and the Excursion in my sig are set up similar but the EGT's in my Excursion are always close to 200* hotter. Is the probe location the difference? I should also note that I have a Quazilla Commander reading the EGT's in my Excursion and analog gauges in my truck.
Thanks
Thanks
Thanks
Thanks
When the wastegate opens it only vents the front three cylinders, that's why it's recommended to tap into the rear chamber, it's the hottest.
th_racer
04-12-2009 12:16 AM
mar67655
03-17-2009 07:57 PM
GlennRMK
04-10-2006 10:11 AM
robwashu
15
08-27-2005 06:29 PM
