Easy way to access Star Wheel
Old 02-24-2003 | 04:43 PM
mymaur's Avatar
I have read a lot of threads about removing the dreaded cap screw, to access the Star Wheel. I've read &quot;use an 8mm allen wrench and hit it with a hammer&quot;, &quot;use vice grips&quot;, &quot;use a chisel&quot;? A chisel on the AFC???? [eyecrazy<br><br>So this weekend I looked at mine and here is what I did. A 5/16th hex head, socket driver, which is the same size as an 8mm, with a 6 inch extension and a ratchet takes the plug right out. All 3/8ths drive. Couldn't be easier.<br><br>Also, ran the wheel all the way forward, No smoke, but I run a K&amp;N filter. Does have a bit more pep and spool up is noticeably quicker.<br><br>This method worked on both my trucks.<br><br>Hope this helps some one!
Old 02-24-2003 | 05:24 PM
Mostwanted's Avatar
Re:Easy way to access Star Wheel
i just tapped around the head of it and used my kungfu grip on a 8mm allen wrench. not much smoke either :P
Old 02-24-2003 | 06:28 PM
mymaur's Avatar
Yea, I always heard the smoke could be real big on acceleration, but I got zero and I have the wheel as far forward as it will go. Course, I don't want the smoke either . Although some seem to like it.
Old 02-24-2003 | 08:08 PM
richard's Avatar
After I adjusted mine all the way forward there was a noticeable difference in smoke. I also noticed that on takeoff, it seemed to be a little more responsive. <br>Just my .02<br><br>Rich
carid
09-16-2015 09:23 AM
skyjumper
08-31-2010 07:08 AM
thebestofindica
07-20-2009 12:16 AM
Brendan
09-25-2008 04:27 PM
kyle_truck_pull
02-21-2008 01:15 PM
