dosent idle
dosent idle
A man ask if i could look at his truck its a 97 auto and it starts a little hard but does start then if you try to let idle i quits but then you can start it every time with a little throttle it drives fine it will soot a little at take off but come to the stop sign and it quits unless you brake with some throttle i went to put a fuel pressure gauge in but forgot that it did not have the 1/8 pipe banjo fitting he said he put new filter and blow out fuel lines a diesel mechanic told him lift pump but i am not sure any ideas thanks oh ya and what is thread is in a stock banjo fitting if any one knows
almost guarantee its simply the idle.theres a bolt and 2 nuts on the back of the pump right below the afc I think,loosen the bottom one and adjust the top one until the idle is set ,then tighten the bottom.they are 10mm
mullishacrew
01-31-2008 02:15 PM
morkable
15
05-24-2007 11:13 PM
