Does it take a genious
Old 03-24-2004 | 04:11 PM
Txwelder's Avatar
What is involved with setting the timing on these trucks and what special tools/skills are required? Thanks in advance.
Old 03-24-2004 | 04:56 PM
MnTom's Avatar
If you want to set the timing, just pull the pump gear and rotate the engine back a little. OK, sounds easy. It really ain't too bad. Go to your truck, find the "CPL" number and go here to find out what your timing should be: http://www.piersdiesel.com/TechPTiming.htm. Once you have that, you need to find #1 top dead center, mark your harmonic balancer, pull #1 delivery valve, set your plunger to what you want for timing, pull the pump gear, then rotate the engine back to TDC (your mark) and reassemble. It really isn't too hard. I was looking for instructions but didn't find them. I am sure somebody else will know where the instructions are.
Tom
Old 03-24-2004 | 05:29 PM
infidel's Avatar
It doesn't take a genius but it takes some somewhat expendsive tools. Most people will be money ahead to let someone else do since it usually only needs to be done once.
Good instructions here-
http://dodgeram.info/tsb/1994/18-10-94a.htm
Old 03-24-2004 | 07:58 PM
MnTom's Avatar
Thanks Bill, That is what I was trying to find.
Tom
Old 03-24-2004 | 11:34 PM
Txwelder's Avatar
Thanks alot. I will just let my friend who is Cummins certified do my timing(Friend = FREE)
Old 03-25-2004 | 06:52 AM
jaconst's Avatar
I have to ask, you are talking about engine timing or pump timing? same thing?
TexasHardcore
06-18-2004 11:18 PM
berner
01-30-2004 07:40 PM
Crabjoe
08-16-2003 10:11 AM
NWDave
03-30-2003 01:43 AM
Quick Reply: Does it take a genious
