Difference between '96 and '98 12v crank sensors?
Old 11-05-2006 | 08:49 AM
v8440's Avatar
Hi all,
Some time ago I was trying to fix my '96-no tach, speedo, and apparently no alternator charging through the normal charging circuit. (someone put an old style mopar voltage regulator in there to get it charging)
Naturally, the first thing I think of with these symptoms is a bad crank sensor. I checked the gap, and it was ok. So, I tried to substitute the sensor off my '98 12v, and then discovered that the plug was different between the two. I thought I'd read several times that the sensors were the same on all the p pumped 12v trucks. Guess not?
Old 11-05-2006 | 12:27 PM
infidel's Avatar
The sensor is the same but the connector is different.
Det 1
17
12-22-2009 09:32 AM
Snoxracer
07-10-2007 03:23 PM
sluggo42
07-09-2007 10:15 PM
jeeptjstud
03-30-2007 01:37 PM
