difference in belt tensioner pulleys???
Old 02-10-2009 | 01:32 PM
lews930's Avatar
Had to take my a/c compressor off for replacement but need the truck. I have a NO A/C belt and the diagram for installation. However, the diagram shows the grooved side of the belt running on the tensioner pulley. Is that ok or is there another pulley available ro run no a/c?
thanks
Old 02-10-2009 | 05:37 PM
dozer12216's Avatar
According to diagram I found a different tensioner and pulley seems indicated. Flat pulley will not work against ribs.
Old 02-10-2009 | 07:30 PM
lews930's Avatar
I called the local Dodge dealer right after posting and the guy in parts said the two pulleys were the same. Dont know if he's right or wrong but it's working. dont know how long it will hold up but it's only until I get my compressor back in.
I'm not sure why people say to keep a non a/c belt for a spare if it wouldnt work.
Old 02-10-2009 | 08:49 PM
Tate's Avatar
I just checked my 01 service manual, it says the same tensioner pulley is used in both A/C and non-A/C systems.
Old 02-11-2009 | 05:27 AM
lews930's Avatar
Thanks Tate. It'll have to do until the compressor is back on. It just doesnt seem right with the grooves on the belt going against the smooth tensioner
Old 02-11-2009 | 12:54 PM
roughstock's Avatar
I've run smooth pulley against ribbed side. I'm in same situation as you. I'm waiting for summer to fix ac. Been 3500 miles with this setup.
Old 02-11-2009 | 08:47 PM
TIMMY22's Avatar
I'm running the no A/C belt on mine. Has been this way for over a year, works fine.
apwatson50
03-03-2006 06:26 PM
Lakemann
20
11-05-2004 07:04 AM
banshee
23
08-16-2004 02:20 PM
Commatoze
10-24-2002 09:32 AM
Quick Reply: difference in belt tensioner pulleys???
