delo 400 sae 30
Old 03-26-2010 | 09:01 PM
Rod meyer's Avatar
delo 400 sae 30
Is Delo 400 30 ok to use in my 12 valve or should I use only 15/40.
This is not the cj4 le.
Old 03-27-2010 | 03:46 PM
DragonSlayer's Avatar
I didn't know there was anything but 15/40. Why would you not run multigrade? That is all we run in the trucks (semi) at work, and they run 48 states and Canada with no oil problems at all.
Old 03-27-2010 | 08:39 PM
johnh's Avatar
i used to use it all summer then i retired to a colder climate,now i use 15/40..........when i was working oil was free .....delo 400 30 w
Old 03-28-2010 | 05:51 AM
infidel's Avatar
Cummins says to run straight 30w in 12 valves used in tropical climates.
Unless you live in south Florida or Hawaii I'd stick with 15w40.
Old 03-28-2010 | 10:04 AM
Rod meyer's Avatar
Thanks guys, I took it back exchanged for Rotella 15/40 ci plus4. All the 15/40 Delo around here is LE only thats why I was asking about the 30w.
Old 03-28-2010 | 09:47 PM
I'm a believer in Delo, but I don't think you will go wrong with Rotella, either. Just don't 'cheap' out on oil.
Old 03-29-2010 | 09:36 PM
dieselman97's Avatar
yea but rotella is a grade 2 oil!
Ironduke10
16
09-29-2013 01:25 PM
Plumb Wild
03-23-2010 08:26 PM
eightball
09-14-2005 08:58 PM
BoldtsWagon
06-15-2004 11:35 PM
Quick Reply: delo 400 sae 30
