delivery valves and injectors
im putting new injectors and delivery valves in my truck and i was wondering if you have to prime the fuel system after you install them? or what you have to do if anything
priming, no. but i would leave the injector lines open a little by the injectors until fuel gets there. dont crank more than 10 sec for the sake of your starter
I would be ready to crack at least the first 3 injector lines before the truck starts. You may have to crack all 6 to get everything primed and running well.
But, it may run just cracking #1.
i cracked all 6 of mine and pump the primer about 50 times. yes 50 times. once you get fuel out of the injector lines tighten them up. also check the green oring s about the dv holder. mine leaked after i swapped my dvs they are cheap. i wanted trust a lift pump to reprime the system, the primer is there for a reason
deezeldude
01-01-2008 10:21 PM
Mcmopar
56
11-16-2005 02:33 PM
Eskimo
14
07-30-2004 10:51 PM
