Crush Washers
Crush Washers
I just want to say thanks for the help, i've come a long way on getting my bargain truck to run like a champ. Im running the stock crushwashers from my old injectors on my 370's and it stumbles and runs really rough at idle. i was wondering where i can get the thin washers from. if i can get them locally, what size amd i looking for. thanks for the help guys, i appreciate it(don't know where i'd be without you guys).
Originally Posted by jughead
everything i have read calls for .020 washers with the 370s. have also heard that one needs at least 181 delivery valves to stop low speed stutter.
thanks, i already put the 191 delivery valves in, helped, but didn't stop it, i'm gonna try the .020 crush washers and see what happens.
Location: Climax, MI (between battlecreek and kalamazoo)
Originally Posted by chop342
you wont fix that stumble completely with those injectors, marine engines have marine pistons which are shaped totally different and run much higher compression. the difference in spray pattern and compression are causing your stumble, which i am guessing is from idle to around to 1100-1200 rpms. stock injectors with schied laser cut dv's flow like crazy. my truck makes more power with stock injectors and schied laser cuts than it did with the 370's and 191's.
97catintenn
07-15-2010 05:46 PM
