Crank Breather?
Old 03-01-2005 | 09:56 PM
SmokinFive9 4x4's Avatar
Crank Breather?
Never noticed this before, but on the cam cover behind the fuel filter there's a 3/4" tube coming out and pointing back and down, is this the breather? I'm assuming so. I'm thinking maybe that's where all the oil is coming from, not the cover gasket itself. If it is, could I run a line up and put a breather filter on it? No harm in that right? Or would it just spit oil all over my newly painted motor and engine bay?
Old 03-02-2005 | 12:22 AM
apache's Avatar
Yes that is the crankcase port for venting. Your supossed to have a plastic hose running down to the bottom of your rig. you will see ocassionally oil drops from it.you can put a barf bottle on the end to prevent dripping, many do. Just remember to empty it now and again.
Old 03-02-2005 | 08:32 AM
zack_76401's Avatar
From: Lingleville TX but active duty Air Force all over the world currently
or route it to your exhaust.......
Old 03-03-2005 | 05:08 PM
So If I route it upwards, with an aftermarket breather on it, what happens? I couldn't imagine it'd do anything but drain back into the motor? can't rotate it can you so that it's pointing up to drain it back into the motor?
Old 09-06-2010 | 08:13 PM
brandon mitchel's Avatar
When it comes to the crankcase fumes returned to the engine, you need to they are clean. Breather filter will block out all the dirt from the crankcase fumes.
Old 09-08-2010 | 12:10 PM
HammerMTB's Avatar
The metal bib for the plastic hose is permanently pointed down. If you route it up, what will happen is the liquid oil will stop at the P-trap you just created. It will gather there until crankcase pressure is enough to blow it out, making a mess whereever the tube ends.
If you HAVE TO go up, put a drainback at the bottom of the P-trap, and let the oil drain from a small orofice there. Then the fumes can go up.
But much better to just put a barf bottle on the bottom, or route to the exhaust.
Jmac
21
04-23-2007 05:44 PM
zero2zero
03-31-2007 11:58 AM
bill7975
01-30-2004 12:03 PM
Jones0027
11-04-2002 07:33 PM
Quick Reply: Crank Breather?
