couple of questions about ball joint repair procedure
I removed the ball joints this afternoon and I'm waiting for the new ones to arrive in the mail. I have a couple of question in the meantime.
First, there is a collar with a hex head in the upper hole on each end of the axle. For now, I have left them alone. Do they need to be adjusted or replaced?
http://i81.photobucket.com/albums/j2...e/IMG_0982.jpg
Second, there was a spacer in between the right wheel and hub, but not one on the left. Would there be a good reason for this? Should I find another spacer or just ditch the one on the right? I'm running stock wheels now, but it had 17" wheels running 297/70's when I bought it.
http://i81.photobucket.com/albums/j2...e/IMG_0981.jpg
Do you guys recommend applying anti-seize to the tapered portion and/or pressed end of the ball joint for easy removal?
http://photobucket.com/97dodge4x4cc
Thanks for the help.
..... 1= bushing to adjust camber...leave it there......2 = shim is in there cause u likely had a brake pulling to the side, lots of trucks have them...try without, u will know if u need it.......3=no...........kim....
Dave2001
01-10-2009 11:50 AM
wcbcruzer
22
04-30-2008 06:58 PM
FDC
07-16-2007 12:51 PM
Lary Ellis (Top)
14
11-15-2002 11:00 AM
