code question
Old 01-10-2007 | 10:30 PM
CButler610's Avatar
code question
I get an intermittent check engine light on my 1994. Checking the codes shows this:
3 flashes -pause- 4 flashes -pause- 6 flashes -pause- then 55
After reading the manual, I am still confused.
Thanks in advance.
Old 01-10-2007 | 10:37 PM
CTDPower11's Avatar
Go to the searrch box and type in error codes or something of that sort... It should give you a page with a buch of codes... Good Luck!
Old 01-10-2007 | 11:05 PM
CButler610's Avatar
Well, thanks for your suggestion but we are talking about something very different than your 2001 that has an ODB II computer. I already have searched for hours and have a manual in front of me. Please re-read my post. I need to decipher what the check engine flashes mean in MY case. I see three flashes, then four, then six. The codes on the 1994 are (2) digit. So, what does this mean?????
Does it mean I have code 34 -and- code 36. If so, I don't see a cose 36, and the code 34 is not cupposed to set the CEL.
Thanks,
Old 01-10-2007 | 11:30 PM
CTDPower11's Avatar
Ok... I take the blame for this one... Sorry, thought I was in the 24v area...
Old 01-11-2007 | 01:20 AM
kerryneb's Avatar
I'm just guessing, but perhaps the first 3 is really a 1 and a 2 = 12 -battery recently disconnected (did you recently [less than about 30 starts ago] replace the battery?). Check the codes again and watch very carefully... the pause between digits is very short. The 46 means the alternator may be starting to go bad...(most likely brushes). Next time it happens, check the voltmeter. You can find the codes at http://allpar.com/fix/80s-codes.html
coope3
02-21-2009 04:49 PM
O.T
09-06-2007 06:10 PM
Terraizer
12-14-2005 03:56 PM
CTD NUT
04-05-2005 04:45 PM
TEDHRS
11-09-2002 12:35 AM
Quick Reply: code question
